LH12
6 years agoFPGAs arrived in jedec trays instead of vacuum pack
I've received few batches of FGPAs from PSG through arrows in jedec trays instead of vacuum packs. What is the risk of storing these parts for the next 24 months ? Is baking a solution for this parts...
ChiaLing_T_Intel
Contributor
6 years agoHi Ling Hong,
Thank you for contacting Intel Community. For your information, to confirm if baking required for the parts received must be referring to the devices' Moisture Sensitivity Level (MSL).
The different devices will have different MSL levels. For example, if a device is classified as MSL 1, it is not moisture sensitive and the device does not have to be dry-packed again after the pack has been opened.
You are recommended to refer to the Moisture Sensitivity Level (MSL) webpage in order to know the humidity environment of FPGA:
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/msl.html
Kindly refer to the MSL baking instruction for more details:
Thank you
Chia Ling
