11 years agoFPGA to SDRAM port access problem
Hello, I have a data file that is read by the HPS... I'm assuming the data block is stored in the SDRAM. This is the C code I used: volatile char *address_pointer = (char*)malloc(bufflengt...
10 years agoHello Patrick,
No I didn't find a way around it. Like others suggested, I did also build the preloader using bsp editor but not too sure what 'free the bridges' means. Anyway, I abandoned the board after a while and went back to using a cyclone 4. Surabhi
