10 years ago[FPGA-to-SDRAM Avalon-MM Bridge] -> beginbursttransfer is missing...
Hi All, I'm working with the ArriaV device and going to use the FPGA-to-SDRAM Avalon-MM Bridge. Does the FPGA-to-SDRAM Avalon-MM Bridge support the burst transactions? After enablin...
10 years ago --- Quote Start --- OK, understood, thank you a lot! --- Quote End --- I'm actually curious about this as I've heard some odd things about AXI support in the Avalon network generated by Qsys. I don't see why it wouldn't support burst transfers, but remember that you're going from an Avalon-MM to an AXI/Avalon slave. I have no idea how the SDRAM module handles the protocol translation!
