12 years agoFPGA to HPS SDRAM Interface
Hi, I want to use the FPGA to HPS SDRAM Interface, in kind of an Avalon MM Bidirectional 64 Bit. Logic is done, simulation results are as expected. I build the design and loaded it into the SoC...
12 years ago --- Quote Start --- So is there any registers to be set before fpga2sdram interface working? --- Quote End --- Thanks for this thread. The security comment helped me. So here is my 50cnts in return. In the design is a HPS with fpga2sdram interface 0 enabled and two JTAG2AVALON MASTERS. 1. JTAG mastter to the fpga2hps bridge 2. JTAG master to the fpga2sdram interface The following works in the system console get_service_paths master set nm_generic_master [lindex [get_service_paths master] <YOUR ID TO JTAG mastter to the fpga2hps bridge>] open_service master $nm_generic_master set nm_sdram_master [lindex [get_service_paths master] <YOUR ID TO JTAG master to the fpga2sdram interface>] open_service master $nm_sdram_master # release fpga2sdram port 0 from reset master_write_32 $nm_generic_master 0xFFC25080 0x0 master_write_32 $nm_generic_master 0xFFC25080 0x111 master_read_32 $nm_generic_master 0xFFC25080 1 # TEST PEEK and POKE at sdram address 768MB set base 0x30000000 # Read at base address through fpga2hps master master_read_32 $nm_generic_master $base 0x8 master_write_32 $nm_generic_master [expr $base + 0x0] 0xDEADBEEF master_read_32 $nm_generic_master $base 0x8 # Read at base address through sdram controller master_read_32 $nm_sdram_master $base 0x8 master_write_32 $nm_sdram_master [expr $base + 0x0] 0xA51CC0DE master_read_32 $nm_sdram_master $base 0x8 # Read at base address through fpga2hps master master_read_32 $nm_generic_master $base 0x8
