10 years agoFPGA-to-HPS bridge, too slow?
Hi, my co-worker is using the Cyclone V with the embedded ARM cores. I often stop by his cube and ask him his opinion of the SoC. His biggest complaint is the FPGA-to-HPS bridge which he says is a bi...
10 years agoOK, I also use Linux. I've not measured latency yet. My test runs for 10 seconds and I get very reproducable bandwidth for each run. How do You write to the bridge? Is it MM Interface and You do a mmap in Linux? Then read/write to virtual adress? Do You use interrupts?
