8 years agofpga startup problem
Good afternoon, members of the forum. I have stratix V. I have such a problem. I write down the firmware in the epcq through the AS. The process is normal. In the firmware, I activate one ...
8 years agoHi,
Are you trying to say, That you have programmed a code to blink single led on the board and you are see different result? 1.Are you using development board / custom board? 2. Check the pin assignments. or 2.Write a simple code to control led via. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
