16 years agoFPGA PS config issue - FPGA not reporting invalid config bitstream
I have a quick question about passive serial configuration. I am using a MAX II CPLD to program an FPGA uisng an RBF file that is stored in flash. The issue I am having is as follows - before t...
16 years agoI'm also using a modified MAX II PFL in a design, but I didn't yet experience the said behaviour, most likely because I didn't try with an erased flash. Your explanation sounds plausible to me, the FPGA seems to wait endlessly for a start of the config bitstream.
As the FPGA apparently doesn't have a timeout, it would be easy to add it in to the PFL design.
