RHura
4 years agoFPGA programming error
I have a custom FPGA board and I am using USB Blaster from TerASIC to program the MAX10 FPGA. Until today, I was able to use the Programmer tool from Quartus to program the FPGA. But now I am g...
ak6dn
4 years agoDo you have more than one of your custom boards to test? Do they all behave the same?
Do you have another TerASIC USB Blaster to test with?
Do you have a different host system to do the programming from (ie, a separate PC)?
Can you successfully use the TerAsic USB Blaster to program another type of FPGA board from your host?
Could be your MAX10 device went bad or your TerAsic USB Blaster is malfunctioning or your software is messed up.
Any one (or all) of these things could be a cause.
