14 years agoFPGA pin assignments - is it good to breakup the buses
Hi, I've got an FPGA sending out two buses (16-bit buses) to a DSP. I'm also sending with the two channels a clock and a frame sync. What is the general rule of thumb when assigning FPGA pin...
14 years agoAt 30 MHz I wouldn't worry too much. So long as you setup your timing constraints, you shouldn't have much of a problem. Stick with the voltage requirements of your DSP (LVCMOS vs LVTTL)
The only thing I would worry about is if you have different voltage requirements on the same bank. (some pins at 3.3 and some at 2.5 etc)
