14 years agoFPGA LCD Problem and Always Construct Problem
I am using the TerasIC DE2-115 with Cyclone IV with Quartus II 10.0 Web Edition and I have two problems:
problem a: lcd display My first problem occurs in the LCD display. I am currently using a slightly modified version of: (remove parenthesis and spaces from (http: )) (http: )//johnloomis.org/digitallab/lcdlab/lcdlab1/lcdlab1.html where I created several additional input wires containing data to be displayed. However, when run on the FPGA, the LCD Display only displays the first set of data, and does not change/refresh when new data is inputted. problem b: always construct I have this weird problem when running a module (shown below). Basically, I have an oracle, in which this module sets an LED to high when it detects that there is a solution to the oracle. I also have another signal (register) which increments for every solution, and displays that number on LEDs.module SolTest(clk, done, veri, Solvout, countOut);
input clk, veri, done;
output reg Solvout;
output reg countOut;
always@(negedge clk)
begin
if((done!==1)&&(veri==1))
begin
Solvout = 1; //1
countOut = countOut + 5'b00001; //2
//countOut = 5'b00001; //3
end
end
endmodule Note: I'm pretty sure that quartus sets an unknown value to 0. It did that for another module that I have. Does anyone know if this is true? A top module connects the outputs to LEDS. I'll list the problems I have here: - module as it is shown (line 1 and 2 un-comment, 3 comment): all LEDs are off (meaning countOut = 5'b00000 and Solvout = 1'b0)
- module with 2 commented out, 3 un-commented (1 unchanged): LED for Solvout is off, LEDs for countOut makes binary 1 (5'b00001)
- module with 2 and 3 commented out (1 unchanged): LED for Solvout is on
Thanks. It seems like a have a different problem.
AIDCheng,
Not sure what exact your problem is but first thing first. Without reset sig, your output will come up in an undefined state (could be 1 or could be 0), it won't always be 0. (I'm sure if you look at warning in synthesis report, it'll warn you of undefined states.) Also, countOut is defined as 6-bit but only the first 5 bits are driven when done != 1 AND veri == 1, and countOut[5] will always remain undefined. Fixed these first and see what happen. In addition, for best coding practice, always use non-block assignment (<=) in sequential construct (i.e., always statement). Take a look at blocking vs. non-blocking assignment. But basically, adopt doing this way: assign output = sig1 & sig2; //Using = here. always @(posedge clk or negedge reset_n) begin if(!reset_n) output <= 1'b0; //reset to benign value else if(sig1 & sig2) output <= 1'b1; //Using <= here. end always@(negedge clk or negedge RESET_N) begin if (!RESET_N) begin Solvout <= 1'b0; countOut <= 6'b000000; end else if ( (done != 1'b1) & (veri == 1'b1)) begin //Put your logic here end end --- Quote Start --- I am using the TerasIC DE2-115 with Cyclone IV with Quartus II 10.0 Web Edition and I have two problems: problem a: lcd display My first problem occurs in the LCD display. I am currently using a slightly modified version of: (remove parenthesis and spaces from (http: )) (http: )//johnloomis.org/digitallab/lcdlab/lcdlab1/lcdlab1.html where I created several additional input wires containing data to be displayed. However, when run on the FPGA, the LCD Display only displays the first set of data, and does not change/refresh when new data is inputted. problem b: always construct I have this weird problem when running a module (shown below). Basically, I have an oracle, in which this module sets an LED to high when it detects that there is a solution to the oracle. I also have another signal (register) which increments for every solution, and displays that number on LEDs.
Note: I'm pretty sure that quartus sets an unknown value to 0. It did that for another module that I have. Does anyone know if this is true? A top module connects the outputs to LEDS. I'll list the problems I have here:module SolTest(clk, done, veri, Solvout, countOut); input clk, veri, done; output reg Solvout; output reg countOut; always@(negedge clk) begin if((done!==1)&&(veri==1)) begin Solvout = 1; //1 countOut = countOut + 5'b00001; //2 //countOut = 5'b00001; //3 end end endmodule- module as it is shown (line 1 and 2 un-comment, 3 comment): all LEDs are off (meaning countOut = 5'b00000 and Solvout = 1'b0)
