AGrig15
6 years agoFPGA is heated like an iron
Hello! Faced a small problem related to the FPGA family Cyclone IV E EP4CE55 in the BGA-484 case. 1 of 2 FPGAs on the same boards and with the same project is heated like an iron. I power the FPGA wi...
Deshi_Intel
6 years agoHi,
Alex has a point. This looks like power short scenario.
- You can probe and measure the power rail to check for voltage drop as sign of power short issue
Some of the factors are either
- On board power rail is shorted
- You can try check for series inductor or resistor component that you can removed to cut off the power for ease of debug
- Another typical failure will be on the blow capacitor that sitted between power and ground that caused the short.
- Basically you need to slowly isolate potential failure parts on your board to find out the root cause
- Another possibility is faulty on board power regulator that you need to replaced
- FPGA internal power rail is shorted which you need to replaced the FPGA
dlim
