13 years agoFPGA instability after reset
Hi all, I am working with a custom Cyclone IV E based HW that is suffering from strange startup instability. The HW runs fine under various stress tests and temperature ranges when programmed...
13 years ago --- Quote Start --- Yes I use PLL locked outputs as reset sources, but the reset code already compensates for possible locked signal toggling during resynchronization period after PLL reset is deasserted. The design is fully constrained, there are no violations reported. --- Quote End --- Great, that eliminates transient timing related issues. --- Quote Start --- the system wakes up, reads firmware header in EPCS, validates checksum, starts copying to RAM and than bum it freezes - reset is not asserted. --- Quote End --- What is doing the copy from RAM? The bootloader? --- Quote Start --- I didn't observe any freezes before execution of bootloader code and none after it - in fact it actually doesn't matter what code I run just after reset it will likely freeze, could be a simple filling of RAM with zeroes. --- Quote End --- Ok, so once your code has jumped into main() and you fill RAM with zeros, you get a lock-up? If you've got to the point that your processor is running, try using the NIOS debugger. Cheers, Dave
