FPGA Initialization / Reset
Thank you for your answers.
In Quartus II Handbook Version 9.1 Volume 1: Design and Synthesis, paragraph Register Power-Up Values in Altera Devices, it seems that there are several ways of initializing the FPGA registers:
1. Quartus II Power-Up Level logic option.
2. Altera_attribute assignment in source code.
3. Quartus II integrated synthesis converts default values for registered signals into Power-Up Level settings.
Therefore, Quartus II reads the initialization values from VHDL / Verilog code. Back in the day, I was told that VHDL / Verilog initialization values were used only for simulation, it seems that is no longer the case.
There is also an important detail described in the handbook, "If the target device architecture does not support two asynchronous control signals, such as aclr and aload, you cannot set a different power-up state and reset state".
We have been doing tests with a Cyclone V that supports aclr and aload.
Power-Up Don't Care option of Quartus II is disabled.
During the tests, the reset signal was always disabled. Hardware Reset = 3.3V -> '1'.
Signals are monitored using signal tap.
We used dummy code to see what happens during FPGA initialization.
The results have been very confusing.
It seems that even if we initialize the signals following the guidelines of Quartus Handbook, the system always goes through the reset statements, even if the hardware reset is disabled.
Dummy code extract below:
type states is (others_s, init_s, reset_s, prueba_s);
signal current_state: states := prueba_s;
signal next_state : states;
signal r_int, next_r_int : std_logic := '1';
signal i_int, next_i_int : std_logic := '1';
signal o_int, next_o_int : std_logic := '1';
process (CLK, RESET)
begin
if (RESET = '0') then
current_state <= reset_s;
r_int <= '0';
i_int <= '0';
o_int <= '0';
elsif (CLK'event and CLK = '1') then
current_state <= next_state;
r_int <= next_r_int;
i_int <= next_i_int;
o_int <= next_o_int;
end if;
end process;
process(current_state, r_int, i_int, o_int)
begin
next_state <= current_state;
next_r_int <= r_int;
next_i_int <= i_int;
next_o_int <= o_int;
case current_state is
when reset_s =>
next_state <= prueba_s;
next_r_int <= '1';
when init_s =>
next_i_int <= '1';
when others_s =>
next_o_int <= '1';
when prueba_s =>
when others =>
next_state <= others_s;
end case;
end process;
R <= r_int;
I <= i_int;
O <= o_int;
The values obtained in signal tap for R, I and O are:
R = '1', I = '0', O = '0'
Since we initialized their values as '1'.
The only way to obtain a '0' is executing the reset statements.
Do you know what can be causing this behaviour?
