12 years agoFPGA GPIO voltage falling
Hi, as part of my final project for elecronic engineering, Ii have designed a 8051 based SoC with SPI master/slave interface. The problem I am facing is as followos: When I transmit SPI da...
12 years ago --- Quote Start --- I did some "debug", and found out, the problem was caused by my BIDIR ports of the SPI slave (my design enables QSPI). once i defined the port as input only, the voltage was O.k. --- Quote End --- Great! Its unlikely you damaged anything, since both drivers were "fighting" with about the same strength (no-one won). --- Quote Start --- after some more debug, i realized, that for some strange reason, the FSM read flag was raised => the inputs were turned over to output (thus explaining why the voltage fell after the first byte...). this is very wierd since i sent a"write" command, and according to my test block, the command was accepted correctly by the slave. do you have any idea how could a signal go high even though on simulation it didn't? --- Quote End --- That sounds like a synchronization issue, eg., you're looking at signals from outside the FPGA that are not synchronous to your FSM clock. Check you have included synchronization logic where it is needed, and that you have correct timing constraints in your design. This thread has a TimeQuest example for QSPI flash http://www.alteraforum.com/forum/showthread.php?t=41009 Cheers, Dave
