10 years agoFPGA full reconfiguration using MAX II CPLD
Hi all, I am trying to command full FPGA configuration using MAX II CPLD embedded on the Transceiver Signal Integrity Development Kit with Stratix V. In the documentation the S5 (connected...
10 years agoI understand - and I agree. Button S5 does not appear to be connected in the System controller code - not the code that comes with the kit anyway.
Hooking 'nRESET' up to the reset generator block seems logical - but you say you've already tried that...? Just to be clear (and I apologise if this is teaching you to suck eggs), you changed line 321 [max_s5_si.vhd] to:reset_in => nRESET,I'm struggling to see why this doesn't work. The quick start guide states: --- Quote Start --- Reconfigure the FPGA with the new files by changing jumper J28 back to user position, then repowering your board or pushing RESET (S5) to reconfigure the FPGA. --- Quote End --- However, it's clear from the code included with the kit that S5 isn't even connected up. So, I'd raise a ticket with Altera. Cheers, Alex
