10 years agoFPGA full reconfiguration using MAX II CPLD
Hi all, I am trying to command full FPGA configuration using MAX II CPLD embedded on the Transceiver Signal Integrity Development Kit with Stratix V. In the documentation the S5 (connected...
10 years agoHi Alex,
Actually, that is exactly what I want. The only problem is It doesn't work! I downloaded the MAX II RTL source code (kit installation : https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-transceiver-si-stratix-v.html) and the signal related to the push button is not even connected to the rest of the design. The first thing I tried is to simply connect this signal to the reset generator module which generates the reset signal for the rest of the modules but I couldn't reconfigure the FPGA. Then I performed several modifications in other modules trying to use pfl_nreconfigure(pfl_control module) or srst (fgpa_interface <-> pfl_control modules) signals in order to perform this reset using the S5 push button but nothing worked. Since the SRST button is disabled even in the Board Test System GUI I am wondering if it is even possible to perform this reconfiguration from the flash memory as documented in the user and reference manuals for the board. Cheers, Filip
