10 years agoFPGA full reconfiguration using MAX II CPLD
Hi all, I am trying to command full FPGA configuration using MAX II CPLD embedded on the Transceiver Signal Integrity Development Kit with Stratix V. In the documentation the S5 (connected...
10 years agoI don't think you've explained your question clearly enough. Pressing S5 - a push button - will cause the MAX II System Controller to reconfigure the FPGA.
--- Quote Start --- Is there a way to do it using the push button as documented in the user guide and reference manual ? --- Quote End --- S5 is a push button. So, is this not exactly what you want? Cheers, Alex
