10 years agoFPGA full reconfiguration using MAX II CPLD
Hi all, I am trying to command full FPGA configuration using MAX II CPLD embedded on the Transceiver Signal Integrity Development Kit with Stratix V. In the documentation the S5 (connected...
10 years agoThis is the information provided in the user manual:
Configuration This section describes the FPGA, flash memory, and MAX II CPLD System Controller device programming methods supported by the Stratix V GX transceiver signal integrity development board. The Stratix V GX transceiver signal integrity development board supports three configuration methods: ■ Embedded USB-Blaster is the default method for configuring the FPGA at any time using the Quartus II Programmer in JTAG mode with the supplied USB cable. ■ MAX II and flash FPP download for configuring the FPGA using stored images from the flash on either power-up or pressing the reset push-button (S5). ■ JTAG header (J93) for initial debugging an d to bring up the on-board USB-Blaster circuitry. link: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/rm_svgx_si_dev_board.pdf
