18 years agoFPGA family selection (novice) problem.
Hello, I'm new to the FPGA devices (up to now I have done only a few simple project on the CPLDs). I have to design a bandpass FIR filter which will be working with a 16bit ADC, at 100MHz o...
18 years agoJust to chip in on the subject of device size. Some of the devices have a migration path to a larger device in the same package - be careful though there can be one or two pins which aren't exactly compatible - easily solved if you are aware of it.
