KNGanendraMurthy
4 years agoFPGA Enumeration Failure
Hi all,
I am trying to program Intel Arria 10 GX Programmable Acceleration Card through RISC-V CPU(SoC) based Hifive Sifive Unmatched Board via PCI express.I am booting up RISC-V CPU using Ubuntu 2...
JohnT_Altera
4 years agoHi,
If you are using default OS, can you detect the device using "lspci" I suspect that the instruction used in RISC-V and X86 CPU is differently.
- KNGanendraMurthy4 years ago
I am able to check the Intel Arria 10 GX PAC card connection to PCI express of Hifive Sifive Unmatched Board which contains RISC-V CPU as (SoC).I am attaching the output generated from the Ubuntu 21.10 OS Terminal.Kindly check and provide suitable solution to the problem
Thanks&Regards
KN Ganendra Murthy
