FPGA Enumeration Failure
May I know if this is performed using Arria 10 Programmable Acceleration Stack or custom build OPAE stack? Can you try to connect to X86 to see if you are facing this issue?
- KNGanendraMurthy4 years ago
The error is being generated at boot-time of RISC-V CPU.I am using Ubuntu 21.10 OS on RISC-V CPU which has default dfl-pci modules.I am trying to program Intel Arria 10 GX Programmable Acceleration Card through RISC-V CPU(SoC) on Hifive Sifive Unmatched Board via PCI express.The kernel version of the OS is 5.13.0-1004-generic of the RISC-V CPU
Intel Accelerator Dev Stack is working properly for x86 system
I tried to install RTE and Acceleration Stack on RISC-V CPU system to program PAC card but it did not work out.Kindly provide suitable solution to the problem
Thanks&Regards
KN Ganendra Murthy
