13 years agoFPGA cyclone EP1C12Q240C8n
Hello everyone,
I am trying to develop a FPGA(EP1C12Q240C8n) based vibration measuring system.The signal processing circuit of the vibration sensor gives 4 analog voltage signal as output. Next these signals are fed to FPGA kit where I have to perform the following task: 1. 12 bit ADC conversion for 4 analog signals and storing the digital output in RAM. 2. Designing a digital processing circuit to perform various arithmetic operations (i.e. summing ,multiplying ,square rooting etc) with the stored datas in RAM . 3. After that I would like to analyze the stored data from RAM to show the maximum, minimum value, frequency, positive and negative discrete values of amplitude with continuous changing input. so plz tell me how i can store the timing data as well as changing amplitude in a RAM, and from this RAM how can i access the datas plz guide me. th thank you12 Replies
I don't use schematics in FPGA design. It is possible, but it will get very complicated, quickly. You'll need counters for the addresses and at least a state machine to control the whole process. It will be a lot easier to do in VHDL or Verilog than with schematics in my opinion.
You can't directly connect the write address signal to an ADC pin. You need a state machine that will execute operations in sequence, first get a sample from the ADC and then write the value to the memory. - Altera_Forum
Thank you Daixiwen.. i will try this..
