14 years agoFPGA cyclone EP1C12Q240C8n
Hello everyone, I am trying to develop a FPGA(EP1C12Q240C8n) based vibration measuring system.The signal processing circuit of the vibration sensor gives 4 analog voltage signal as output. Nex...
14 years agoi am using .bdf for design ADC as well as ram. actully i dont know it is right way or wrong, to connect ADC with RAM using .bdf.
Because when i try to connect Ram with ADC i am getting no output from RAM when i see in signal tap ii window. may be write address signal(wraddr) , which is an input to Ram is not working properly. i can't understand this signal (wraddr)is connected to the which output pin of ADC. so please tell me it is possible to connect ADC with RAM using .bdf is possible or not... Thank you
