14 years agoFPGA cyclone EP1C12Q240C8n
Hello everyone, I am trying to develop a FPGA(EP1C12Q240C8n) based vibration measuring system.The signal processing circuit of the vibration sensor gives 4 analog voltage signal as output. Nex...
14 years agoThank you very much Daixiwen for your reply.
actually i am using right now signal tap ii, its gives me hex values of ADC output. now if i like to reconstruct the original signal, or if i want to see the amplitude vs time graph from that hex values of signal tap ii, than it is possible or not . Is there any way to see that type of graph, because i like to find out the maximum amplitude as well as the minimum amplitude with time. so please if it is possible than help me. Thank you
