17 years agoFPGA Configuration using CPLD!
Hi all, I have a question need your precious comments. As I create my pcb with a Arria and MAXII. I planned to use Paralle Flash Loader in CPLD to configurate Arria. After following AN3...
17 years agoTake a look at this document:
http://www.altera.com/literature/hb/agx/agx_52011.pdf Any chance the pull-up on conf_done or nStatus is missing? Posting the .cof file and the PFL megawizard generated .v or .vhd file might provide some clues. What is MSEL(3:0) set too? Is the .sof file you are using have compression enabled(see figure 11.1 of above document)? If you are using compression, read pages 11-5 and 11-6.
