17 years agoFPGA Configuration using CPLD!
Hi all, I have a question need your precious comments. As I create my pcb with a Arria and MAXII. I planned to use Paralle Flash Loader in CPLD to configurate Arria. After following AN3...
17 years agoHi Johnson,
Are you using FPP with decompression mode? If so, MSEL(3:0) should be set "1011" which makes Arria to know receiving data compressed. The compress option should be set when generating POF, which generate compressed POF. There is a flag to show data is compressed in the POF, so the PFL knows it and send data in every four dclk. You can find the PFL source code in C:\altera\81\quartus\libraries\megafunctions folder, but unfortunately Altera doesn't disclose the details on how PFL works. Thanks,
