17 years agoFPGA Configuration using CPLD!
Hi all, I have a question need your precious comments. As I create my pcb with a Arria and MAXII. I planned to use Paralle Flash Loader in CPLD to configurate Arria. After following AN3...
17 years agoHi Johnson,
The remote system upgrade settings enables state machine in the Arria to control retrying configuration. If you choose FPP w/ decompression setting, you should set appropriate option when creating POF file. The PFL and Arria know whether the data is compressed or not from the POF format. To create decompressed POF, you should check the compress button which appears pressing property. Regards,
