13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- Are You sure, that PFL input Clock = 12MHz clock is enough for MAX II to configure EP4CGX22 from a single Quad SPI ( N25Q128A13ESE40G ) in PS within below 50 ms ( as a conservative approach )? --- Quote End --- The 12MHz was the minimum clock frequency. I'd run the design at 50MHz or 100MHz, whatever worked for your design, eg., use a clock frequency that you already have on the PCB. Cheers, Dave
