13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- What is "reset supervisor" delay inside the FPGA? --- Quote End --- Its the logic that implements POR. If you were to create a design with a RST# signal going into the FPGA, then you would typically use a reset supervisor IC to "debounce" the reset signal, eg., a push button. --- Quote Start --- I don't see any straight-forward statment in Handbook, that tells to add tRAMP + tPOR, that is 3ms + 9ms. --- Quote End --- Its a conservative calculation, i.e., if you select MSEL for "Fast" POR, then your power supplies have to meet the tRAMP time, and following that tPOR will occur. Arguably tRAMP is tPOR(min), so you could just use tPOR(max) = 9ms. However, if you're within 3ms of the 100ms requirement, you're too close, and your system would likely fail in many systems, since even the 100ms value is not a guarantee. Read the references in the PDF link I gave above. Cheers, Dave
