13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- The timing parameters are in the response above; you have the power-on time of tRAMP < 3ms, after which point the POR time completes, the device deasserts nSTATUS and starts the configuration process. Look at the AS mode timing diagram for the "extra" delays - but they're microseconds, so can be ignored if you set your 100ms limit a little lower, eg., 95ms. Cheers, Dave --- Quote End --- I found Your paper ( cpci_power_on_timing.pdf ), that calculates total configuration time for EP4CGX15. Here is a quote frome it: the configuration time for a cyclone iv gx ep4cgx15 configured via fast passive
parallel (fpp) mode using a 66mhz clock is; 3ms power-supply ramp + 9ms power-onreset
delay + 3,805,568-bits/66mhz = 70ms. Of course FPP is not applicable to EP4CGX15, but the calculation is also misleading... Please explain why did You interpret Table 1–4. Recommended Operating Conditions for Cyclone IV GX Devices (Part 2 of 2) in such a way: "3ms power-supply ramp + 9ms power-onreset delay"? https://www.alteraforum.com/forum/attachment.php?attachmentid=7868
