13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- Now getting back to the very beginning to what I was asking for: What timings ( POR-related, etc. ) I have to add to calculate that extra time? --- Quote End --- The timing parameters are in the response above; you have the power-on time of tRAMP < 3ms, after which point the POR time completes, the device deasserts nSTATUS and starts the configuration process. Look at the AS mode timing diagram for the "extra" delays - but they're microseconds, so can be ignored if you set your 100ms limit a little lower, eg., 95ms. If you have an FPGA development kit, eg., a DE0-nano, then go and measure the signals on that board too. That will give you a good idea of how well the handbook numbers reflect reality. Cheers, Dave
