13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- You're on the right track for determining what timing parameters are needed, but if you use the worst-case values for the AS mode parameters, then you cannot hit the 100ms window. Cheers, Dave --- Quote End --- What are the worst-case values for the AS mode parameters for EP4CGX22 + EPCS4 bundle? I mean - everything besides configuration time to transfer bitstream. Knowing it I can calculate how many bits of configuration file will go through the rest of 100 ms window and only after this I can see - will my project squeeze in.
