13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years agoThanks Nial,
I have tried the start -> move mouse to the shutdown box -> select restart. I got to thinking to try start -> then enter restart in the search rectangle and a restart executable was found and when I ran it .... it did exactly what I wanted. ( of interest is that the same executable is not found in this HP Windows 7 laptop, but is on the HP 220 deskside I purchased for to get PCIe Gen3 slots ??? for PCIe work ) The Windows shut down, screen blanked, and POST / BIOS restarted without the power being cycled off and on. I use PCIscope to display the PCI system status. That tool seems good for Windows, is there a Linux equivalent one ? and the example Altera DMA application ran. Didn't seem to fix the issue but I was able to get the FPGA Development card to come up , be recognized when run in slot 1 ... the x4 / x8 Gen2 slot . The development card is configured for X8 Gen2 and I made sure the X1, X4, X8 present# signals were switched to just X8. Switches may have been in the wrong position ? I have a feeling that possibly the slots in this system may be set to support certain speeds and a certain set of lane widths . I can test this by trying to reconfigure the card for X1 Gen2 and change the capability switch for X1 present# and see if it still trains and is identified in the same slot. Thanks for all the help.... I can now go ahead and add the NIOS II and our own IP to the Stratix -V development board. Any ideas on simpler boards supporting PCIe X1, X4, X8 @ Gen3, Gen2, Gen1 speeds with a Stratix -V and some external DDR memorty. Best Regards , Have a great Friday, Bob Dixon.
