13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years agoMight be worth trying to load a very minimal fpga image - maybe little more than a single PCIe BAR connected to an M9K block.
Another problem I've not seen a solution to is how to select a 'factory' image when using CvP, especialy if using AS to load the periphery image. There almost certainly isn't time to load a small image from the start of the EPCS which then determines whether to reload using either a 'factory' or 'user' image. If PS is used you can use a jumper to select the EPCS offset - not ideal, but better than having to use JTAG. Without that you always need the rest of the image in order to program a different one.
