13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- I still need to add the RST# signal ... included and the Windows 7 seems to take the power supplies down on a restart ... I have tried to check the POST / BIOS for a configuration to disable this but have not found one. --- Quote End --- I haven't seen that in the system I tested with. --- Quote Start --- I have tried to interrupt the POST / BIOS but it didn't seem to make any difference ... I believe I need to configure the Signaltrace to FLASH to see if I can capture the rising edge of RST# Otherwise I will need to check the rising edge of RST# and the signal indicating the FPGA is configured and running. --- Quote End --- SignalTap II has a power-on trigger option. You can configure SignalTap II to trigger on the rising-edge of RST#, and then download the trace at a later time. I'm pretty sure I included traces captured using this method in the PDF in this thread: http://www.alteraforum.com/forum/showthread.php?t=35678 Cheers, Dave
