13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years agoThanks dwh ...
I was able to ge the Signaltrap into the design and have it trigger. The ltssm seems to be cycling through states 0, 1 and 2. I still need to add the RST# signal ... included and the Windows 7 seems to take the power supplies down on a restart ... I have tried to check the POST / BIOS for a configuration to disable this but have not found one. I have tried to interrupt the POST / BIOS but it didn't seem to make any difference ... I believe I need to configure the Signaltrace to FLASH to see if I can capture the rising edge of RST# Otherwise I will need to check the rising edge of RST# and the signal indicating the FPGA is configured and running.
