13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- am wondering if there is some race between the training and the BIOS comming up ? --- Quote End --- If you were able to build the design, then try adding a SignalTap II instance and probing PCI RST#. Perform a warm reboot of your system, and you should see a rising-edge on RST#. That indicates your FPGA was alive before the BIOS attempted to enumerate, so the issue is not a race condition. If you can get the card to boot ok on warm reboot, but not at power-on, then you might have a race condition. Cheers, Dave
