17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoHi Jake,
following are the signals which i have mapped to the MAXII device: fpga_conf_done, fpga_nstatus, fpga_pgm, pfl_clk, pfl_flash_access_granted, (always pulled to high) pfl_nreset, (always pulled to high) flash_addr, flash_data, flash_nce, flash_noe, flash_nwe, fpga_data, fpga_dclk, fpga_nconfig, pfl_flash_access_request (high) and the settings for the S6 dip switch are: CONFIG_MODE0 - low CONFIG_MODE1 - low DIPSW_PGM0 - high (if i am connecting fpga_pgm pins to dip switch pgm pins of the max device) DIPSW_PGM1 - low DIPSW_PGM2 - low VCCHTX_ADJ - low RUnLU - high HSMCA_JTAG - high HSMCB_JTAG - high CLK_SEL - high thanx -Amit
