FPGA configuration file size
Now I used Stratix10 Device and use .jic file to configure my device. The size of the configuration file will change with my design(found in .map). So I would like to ask what is the maximum configuration file size of each device? Is there a corresponding document to explain? I did't see any corresponding table in Intel® Stratix® 10 Configuration User Guide.
Thanks a lot !!!
Hi DeXin,
You may find the information at link below ya.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_datasheet.pdf (Page 110)
Thank You.
- YuanLi_S_Intel
I am glad it solves you problem. I am closing the thread now. If you feel our support is good, kindly give good rating ya. Thanks!
- YuanLi_S_Intel
Hi DeXin,
Thank You.
- GDeXi
You solve my problems
Thanks!!!
