14 years agoFPGA architecture
Hi all, I'm starting a new project and I need some help with the FPGA architecture. The concept is very simple - the FPGA will sample an input parallel bus (24 or 48 signals @ 150MHz max) and stre...
14 years agoI didn't know that. The thing is that I need to transfer a lot of data (about 6.5Gbps) and the local Altera representative recommended to purchase PLDA's IP. They also sell the windows driver so I need that anyway. I assume that I won't achieve the same performance using only the Altera core? Do you know whether the core itself is similar to PLDA's core or is it completely different (inputs, clocks etc.)? Is there an application that I can use with Altera's core in order to stream data to a PC and test the PCIe throughput?
