10 years agoFPGA + Camera iamge sensors
Can any one recommend a camera sensor that can be easily attached to the FPGA? I don't need high frame rates. It is a simple project related to image processing. I found some people use OV7670 b...
10 years agoOk, but you don't want to read a prestored image?
A small image processing project, does this mean it is a small project or a small image? I take the latter to mean low resolution. You have already said you don't care much about the framerate, so then it is a matter of costs and available connections to the FPGA. Howmany IOs do you have available, which FPGA is on your board? I don't have a specific chip or camera to reccommend to you. You might also want to take a look at some (free) IP that others have created to read from a camera. It may be you can do what you want with an old consumer handheld camera that has video out, but that might require ad converters.
