10 years agoFPGA + Camera iamge sensors
Can any one recommend a camera sensor that can be easily attached to the FPGA? I don't need high frame rates. It is a simple project related to image processing. I found some people use OV7670 b...
10 years agowhat is the FPGA? Is this a dev board, custom design or so ething else?
Tere are a lot of protocols, so I would reccommend doing what you are doing and first select a camera an then look at thenprotocol and see if you think you can implement this.
