For the input FPGA pin, can I configure the IO_STANDARD to "3.0-V LVTTL" if the signal comes at 3.3V level? Is it safe for FPGA I/O operation? Are any pros and cons of using "3.0-V LVTTL" I/O standard when signal is at 3.3V level?
Hi Andrey,
You can use 3.0-V LVTTL" I/O standard with VCCIO 3.3V.
But to have a signal of 3.3v it should match the vih and vil requirements with respect to 3.0-V LVTTL" I/O standard.
I think using 3.0-V-LVTTL I/O standard has more Current Strength capabilities (4 mA, 8 mA, 12 mA, 16 mA, Max) vs. 3.3-V-LVTTL (4 mA, 8 mA, Max). Do you agree?
Yes,you are correct refer table 4 from below link.
Do you know to what value Max corresponds to?
Max current is depended on the driver/ receiver and FPGA. It will be around maximum absolute value.To get exact max current we need to do IBIS simulation by having both IBIS model.
Intel recommends that you perform IBIS or SPICE simulations to determine the best current strength setting for your specific application.
When we talked about PCI-clamp diode. What is PCI stands for?
PCI (Peripheral Component Interconnect)-bus clamp diodes in the FPGA’s I/O blocks to prevent damage to the FPGA (Figure 1). The PCI clamp diode limits the voltage to a level that doesn’t harm the input.
Refer link for more information
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an447.pdf
Anand
