16 years ago
for loop
Hello there,
I have a question,
i have a std_logic_vector(20 downto 0) and i want to take the value
of this vector to build a for-loop.
for example the std_logic_vector looks like that
"000000000000000000101" which is a value of 5
now i want to build a for loop so that my output
out_data = X"80008000"
fills out_data with X"80008000" 5 times befor other values are coming
Could anyone help me how i could build this for loop?
regards
    HelloIm trying to do a series of Rolling Correlations using movcor command. Already did it for one series, with respect 10 other series.The problem is I need to do the same process, with respect to other series. Is there a loop I can use here, and save some time?Thanks for any suggestionsJoaquÃ*n
    OK thanks for that will give them a try when my HT5 Head comes back from repair
    for loop isn't quite the same as in the C/software world.
    what you need to do is something like a mux which has your X"80008000" value on one input and the signal which will have the following values on the other input. a counter will count up to 5 then using a comparator will switch between the two mux inputs.
