12 years agoFMC vs interlaken
hi, what is the difference betwwen interlaken and FMC? thx
12 years agoYou can't really compare FMC and Interlaken. There isn't anything the same about them - except, perhaps, they're both aimed at supporting higher bit rates.
FMC is Altera's name for a type of physical connector that they (and others) use. Interlaken is a protocol that you might run over a physical link that may (or may not) run over an FMC connector. Have a read of: http://www.altera.com/technology/high_speed/protocols/interlaken/pro-interlaken.html (http://www.altera.com/technology/high_speed/protocols/interlaken/pro-interlaken.html) to give you an overview of Interlaken. Altera's FMC is a custom connector made by Samtec, part number: ASP-134486-01 http://www.samtec.com/documents/webfiles/cpdf/asp-134486-01-mkt.pdf (http://www.samtec.com/documents/webfiles/cpdf/asp-134486-01-mkt.pdf) This connector is used on a number of Altera's development boards.
