10 years agoFmax of design
Hi, I designed a processor using VHDL on Quartus II, but I didnt know how to determine its fmax. Where in quartus can report this? Or I should be use ModelSim to check it? Thank you
10 years agoIf you created processor why you don't compute operation per second??
but yes you can use TimeQuest and if you will wonder with results you need make analysis of reprot for Analysis and Synthesis phase, that you need to do the same for Fitter phase, then it is all. but have you run Design Space Explore for your project assignments? Hope you do project compilation with real coomands in SDC file.
