10 years agoFmax of design
Hi, I designed a processor using VHDL on Quartus II, but I didnt know how to determine its fmax. Where in quartus can report this? Or I should be use ModelSim to check it? Thank you
10 years agoRun timequest. If you have not provided any constraints it will apply a constraint to all signals it determines to be clocks as 1000MHz, then it will give you the FMax in the appropriate temperature model report.
