11 years agoFmax Improvment
I'm trying to improve Fmax in our design. See the archived quartus II proejct file in the attachment. The source files are also attached. In my currrent design, after compilation, Fmax can reach ...
11 years ago --- Quote Start --- You can find a lot of examples of pipelines in books and on web. Have you found where to insert pipeline in VHDL? --- Quote End --- I think I should insert pipeline in the code below. Am I right?
-- Gray bar(16 gray bars)
HelperGrayBar <= "1111"; -- gray level 15
if unsigned(Setting_Pixel) < shift_right(unsigned(Setting_TotPixel),4) then
HelperGrayBar <= "0000"; -- black
elsif unsigned(Setting_Pixel) < shift_right(unsigned(Setting_TotPixel),3) then
HelperGrayBar <= "0001"; -- gray level 1
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),3)) + (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "0010"; -- gray level 2
elsif unsigned(Setting_Pixel) < shift_right(unsigned(Setting_TotPixel),2) then
HelperGrayBar <= "0011"; -- gray level 3
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),2)) + (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "0100"; -- gray level 4
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),2)) + (shift_right(unsigned(Setting_TotPixel),3))) then
HelperGrayBar <= "0101"; -- gray level 5
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) - (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "0110"; -- gray level 6
elsif unsigned(Setting_Pixel) < (shift_right(unsigned(Setting_TotPixel),1)) then
HelperGrayBar <= "0111"; -- gray level 7
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) + (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "1000"; -- gray level 8
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) + (shift_right(unsigned(Setting_TotPixel),3))) then
HelperGrayBar <= "1001"; -- gray level 9
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) + (shift_right(unsigned(Setting_TotPixel),3)) + (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "1010"; -- gray level 10
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) + (shift_right(unsigned(Setting_TotPixel),2))) then
HelperGrayBar <= "1011"; -- gray level 11
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) + (shift_right(unsigned(Setting_TotPixel),2)) + (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "1100"; -- gray level 12
elsif unsigned(Setting_Pixel) < ((shift_right(unsigned(Setting_TotPixel),1)) + (shift_right(unsigned(Setting_TotPixel),2)) + (shift_right(unsigned(Setting_TotPixel),3))) then
HelperGrayBar <= "1101"; -- gray level 13
elsif unsigned(Setting_Pixel) < (unsigned(Setting_TotPixel) - (shift_right(unsigned(Setting_TotPixel),4))) then
HelperGrayBar <= "1110"; -- gray level 14
end if; If there are some limitation of the resources that i'm not allowed to add more pipeline, do you have some ideas to simplify the logic in my design?
