11 years agoFmax Improvment
I'm trying to improve Fmax in our design. See the archived quartus II proejct file in the attachment. The source files are also attached. In my currrent design, after compilation, Fmax can reach ...
11 years agoThank you! Tricky.
--- Quote Start --- The usual way to improve timing is reduce the amount of logic between registers. Use tier quest to find the worst paths and reduce the logic. Then improve this paths and keep on working on the next worry paths. --- Quote End --- I'm new to time quest. Could you help to be more specific? Or some documents you can recommend?
