10 years agoFloating point addition in vhdl
Hii
I want to add 4 floating point no.what will be the result range.I am using library ieee_proposed; use ieee_proposed.fixed_pkg.all; this package.For example if I want to add two floating point no then the result range is C= A+ B -- range of C is (max(A'right ,B'right)+1 downto min (A'left ,B'left)) and it is working fine .But when I am doing C = A+B+D+E; What will be the new C range. If I am following the same as above I am getting an error "D:/214ee1411/vhdl codes/floatarith/mul_1test/fmul_1.vhd" Line 50: Expression has 11 elements ; expected 9 Please help me with this. Thank you11 Replies
You are using fixed point?
